Sold: AR7200BX w/USB dongle $140
xokia
This is the beastx out of my trex 250 that I sold. I purchased it new but ground down the side of the case so it would fit in the frame of a 250 DFC without touching the frame. I removed .5mm from each side. There is still plenty of metal remaining. The top of the beastx still has the protective film. It's 100% functional and nothing wrong with it. It also comes with the USB dongle and cable.
xokia
Question, did you remove the innards when you ground on it?
Yes of course otherwise I would have ground down the antenna lol Not to mention the obvious of not wanting metal shavings in with the electronics.
If anyone is concerned I can take more pictures if requested. It actually looks pretty dang decent. The pictures make it look worse then it does in person. It's even all the way across.
If the protective film was removed the top would look new. I'm selling because I decided not to stick in my trex 450 instead I'm going to buy a 3rd helicommand.
I was just making sure that no high res vibrations were put into the gyro sensors. It's all good. You have a PM.
