I can't figure this out....swash is moving in the righ direction on all the other steps but when I get here the swash does not stay at its high point regardless of the two settings....somebody help
If you are in step N, the way to check the swash is to hold the head and rotate the helicopter. The swash should stay tilted in the same direction. So if the swash it tilted to the right, then as you rotate the helicopter, the swash should always be tilted to your right regardless of the helicopter position. I think that is N anyway.
