ar7200bx help
hi I have a dx9 and the ar7200bx and cant get how to set up so I can switch from rate mode to heading lock mode ......thanks thecopterboy
Make sure in the gyro menu that the channel is set to gear or channel 5 ( I had it wrong in the pm, was thinking 3gx, sorry) and you are on a switch that you can easily reach when flying.
hi so how do I get it to go back to the headlock mode I got it to go in to rate mode and cant get it to go back now help thanks thecopterboy...
Go into the gyro menu, and make sure you have a positive number. I would start around +45.
