  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Ar 7200bx Trim Confusion
Discussion in 'Helicopters' started by Mikker, Feb 9, 2020.
< Mcpx Bl2 Anyone? | Esc Beep >
  1. Mikker
    Mikker Member
    Apr 10, 2016
    52
    0
    6
    Oklahoma
    I have a pair of helis that both have the AR7200BX RX. After reading the owners manual for this receiver, I found a page that states to NOT USE THE TX TRIMS. Really? So if I understand this right. I have to mechanically set the helicopter up perfectly by adjusting links for all trim deviation? 0E5F40F9-086C-430A-B6F5-3F15A65AF0EB.png
  2. D.O.G.
    D.O.G. Well-Known Member Goblin 380 Supporter
    Jul 9, 2013
    3,176
    137
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Hey there Mikker. I have 2 AR7200BX and 1 AR7300BX and that's statement is very true :). When you get to letter "J" which I call the blue light special lol, Don't panic if the blue light doesn't pop up when you get 6 degrees of cyclic. A lot of individuals can't get the 6 degrees cyclic and the blue light to light up at the same time. Just make sure you get the 6 degrees on the cyclic, that's the most important and get close to the blue light as you can. I got lucky and got 6 degrees and the blue light to light up on all 3 of my AR's.
  3. Mikker
    Mikker Member
    Apr 10, 2016
    52
    0
    6
    Oklahoma
    Where is the throttle trim set on the tx , position? At 50%?
  4. Tony
    Feb 21, 2011
    37,097
    1,456
    113
    I leave mine at 50%.
  5. murankar
    Dec 4, 2011
    9,145
    384
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    So for FBL units you want your mechanical set up as close as you can to dead on. Dead on is impossible so dont try. In most cases you can get really close which will be good enough. The FBL will handle a lot of the drift for you so no need to worry about the trims. The trims will confuse the FBL unit and cause a huge headache for you.
    I dont remember how to do things in the AR series line up. Their should be some kind of setting that will allow you to dial out drift. I know you can level the swash in that unit. A level swash will stop most or close to all drifts. Then after a few flights you can tweek your swash settings to near perfect hands off hovering. It will take a good number of flights to get it set the wag you want it.
    Mikker likes this.
  6. Mikker
    Mikker Member
    Apr 10, 2016
    52
    0
    6
    Oklahoma
    Thanks for chiming in guys....now if I could only find a main gear for it....make that 2 main gears...my 270 needs one as well. HH has them on BO till April
  7. D.O.G.
    Jul 9, 2013
    3,176
    137
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
Share This Page
