I finished installing KST 515MG servos for my cyclic on my 500. The tail servo is an Align DS 525M. I'm using AR7300BX for FBL unit and when it comes to programming the AR,Everything is fine when the AR is being set up but when the AR is done initializing then that's a different story. When I move my rudder stick, the tail blades move very slowly and when i move the heli left or right to see if the tail blades are moving in the right direction, NOTHING. My settings are 333Hz and 1520 pulse length. The tail servo worked fine with Turnigy cyclic servos but not the KST. Any ideas, will be well appreciated. Thanks.
