450 Align collared main shaft trueness check???
Bruno
How has anyone checked the "trueness" of an Algn shaft with the integrated bearing stop collar for trueness. Without the collar I would simply roll the shaft on glass.
Not sure how to check for subtle bend with the collared main shaft. :upset:
Any suggestions?
pvolcko
Two pieces of glass, run the collar down the space between. If the underlying surface is uneven you may get a gap between the glass and shaft at some point, but as long as there is no wobble to the gap it's all good.
