skylane733
I had to replace the main shaft. I did a complete head setup from the swash up. I got everything perfectly aligned and used a digital pitch gauge to get the the blades as close to 0 degrees as possible (within .1 degrees). Now the blade track is off by maybe 3/8 of an inch. Do I need to adjust the pitch on the high or low blade?
