If electric is your thing, stick with it man! I started with nitro, then got an electric setup and I started to not like the glow stuff as much (because they're dirty and don't always run the same) If you want to get into fuel powered stuff I would actually recommend a small gas setup, because they are reliable, stay tuned, are cheap to fuel, and the only batteries you have to keep charged are the ignition and rx packs. Electric power, though is nearly on par with gas in my opinion, I guess it depends on the plane and what you want. Electric power is more versatile, you can add a cell and prop down for more speed, prop up for slow flying, or any number of combinations to change flying characteristics.
