Hi everyone, been tuning my first 700n lately and had my first fly around yesterday, It took me 3 or 4 circuits before the nerves settled enough to be able to fly properly. Now I've got it flying really well, still needs a few tweeks on the mixture and maybe increase the head speed of idle up 2 a bit more other than that I'm happy as with it.
Now the thing I want to know is, is it normal for a 700 to shake on spool up around the middle of the spool? it doesn't do it when I first start spinning the blades until they are what I would say is at half speed then it settles down a little after that once I'm nearly up to my head speed ? Both the main blades and tail blades and balanced they weigh the same and sit perfectly level on the see saw, Iv'e tried different tension on the blade grips from tight to almost floppy.
when I started the main blades were very tight in the grips so I sanded them down with a very fine grit on a belt sander until they were just snug in the grips with no play.
another thing I don't like about spooling this beast up is the vibrations tip the swash plate over so I have to watch it very carefully so it doesn't tip over but is rock solid once off the ground, I'm wondering if the shake could have something to do with this as well or is it just nitros?
Another thing I'd like opinions on is how to tune the mixture, I watched a video on youtube to learn, they had the throttle curve at 60% hovering with 5 degrees of pitch and 100% at full with 10-12 degrees of pitch, then doing full throttle climbs leaned out the high needle till it had a nice powerful climb but still not screaming and still plenty of smoke then adjusted the mid needle until it had a steady transition from climb back to hover eg not bogging down (mid to rich) or screaming (mid to lean) all of this is done in normal mode with the governor off.
makes it hard to get back down without the head speed dropping real low because of the 5 degrees pitch at half stick is there a better way? also what sort of temps are you guys running I heard around 180-190f I'm sitting at more like 130-150 which makes me think I could lean it out a bit more currently getting a 8 minute flight just doing figure 8s etc
sorry about the long post guys but wanted to try cover all my questions, looking forward to replys
Cheers
Brent.
(700n pro, ms carbon fiber main blades, align c f tail blade, 3gx, dx9)
Cheers
Brent.
