700 700 tail blade thickness
those of you that own 700 sized heli's...can you tell me what the thickness of the tail blades are at the end of the blade where the bolt hole is? I've got one of those "curious thoughts" running through my head again.
they are 105mm long with a root thickness of 5mm and a bolt hole diameter of 3mm. :admin:
So, you are saying that at the end of the blade, where the bolt hole is, measures at 5mm?
Thanks Tony!
It's going to take some time and a bit of money but if this project works....it's gonna be pretty cool!!!
Just an FYI, the root of the 700 tail blade is the same as the 600. The same size bolt hole, they are just shorter at 95mm. The 550 tail blades are 90mm. So you can use your 600 tail blades to test if you wish.
