Now that you are at 0º pitch, you need to check full positive and full negative. If they are the same (on BOTH blades) then you are done as long as you have about 11º of collective and 8º of cyclic in both directions.
However, if you do not have the same collective pitch up and down, then there is some more adjusting to do. If you have more positive pitch, then you need to lower the swash. If you have more negative, then you need to raise the swash. Once you do that and both are as close as you can get it, go back and set the Tx at mid stick and use the blade grip links to reach 0º of pitch again. Then again, do the full collective up and down and make sure you have the same number positive and negative.
It can take a couple hours to properly setup a head, but it's worth it and I HIGHLY suggest it.
