I just received my new PDB board for my quad project. I'm just looking for clarification.
Here is the PDF manual:
http://www.getfpv.com/media/wysiwyg/product-user-manuals/Lumenier-4POWER-Plus-Manual.pdf
I see where the positive and negative esc leads solder on....in the corners. Simple enough. There are some smaller pads, between the esc leads....is that where I solder the signal wire for the esc? I'm using Little Bee esc's....these are OPTO, so there are only black and white wires coming from the esc. Then, do I run another wire from the S1, S2, S3, and S4 pads (on the left side) to the 1, 2, 3, 4 pads on my flight controller?
Thanks in advance!
Thanks in advance!
