General 450l
jrbrandon
after 6 months not playing with this heli because had problems with gpro. tail would not hold. just got a mricobeastplus and need advice. question running a 1300 battery 22.2 volts and bec can I program the microbeast with this battery. any help would be grateful. thank you.
holtneil
Just use a esc with a bec to give you 5 volts if your running HV servos then you can use a 2 cell battery
Yes you can program the FBL with that battery, but obviously you need to power the FBL via the BEC on the ESC... not directly from the battery.
