Turn your rudder locking gain adjustment back up to suggested. And to lower the gain, you will do that in your Tx in the gyro menu. If you are using just satellite Rx's, make sure your gain channel is set to 7 or Aux2. If you are using a separate Rx, such as the AR6210, then set your gyro gain channel to 5 or Gear.
Let us know your configuration and what Tx you are using and we can help you out even more. As for the other settings, everything looks pretty good.
