Hey guys,
I see that this is an old post but I'm kinda new to FBLs. I just went through the 3GX setup and think I now need to recalibrate the throttle to get the ESC to arm. I can set the low throttle to 133% to get it to arm, but won't a recalibrate take care of this? Anyway, how do you calibrate the ESC with the 3GX? The ESC expects a high pulse on power up (ie. full throttle) to enter calibration mode, but it seems like the ESC is not receiving that and is doing a fast red light flash with the 3GX. Do I need to do a reconfigure on the wiring like I found one video on a calibration with a AR7200BX? This requires another power source, a special cable (throttle cable with voltage removed) so that the FBL can boot up and then you can apply voltage with the FBL outputting the high pulse. Is this necessary? This is a pain since I'm working with a 450 Pro DFC and the 3GX is buried. I would likely need to remove the tail servo to get to the wires in the 3GX.
