Hi all. Just run into something that could or could not be a problem.
I have set the tail up using sub trim on the TX because the push rod seems to long to get even throw on the tail rotor blades at neutral position and now when plugged into the gyro The servo arm is not dead square to the servo but off, not by much but does it matter? Everything works great. Good movement on the tail slider and no binding. This set up is different to the last in the fact that the tail servo can not be moved along the boom for adjustment. I can not shorten the linkage rod because I have no way to make another thread. Any thoughts would be appreciated. Maybe its okay, it seems to work okay but are these famous last words LOL.
