pj1969
Just wondered if anybody has come across this before?? I had to change my front torque tube drive gear, as when i was adjusting tracking, it decided to fail and spin on the shaft. Luckily i keep spares, but have noticed a notchy feel to the gear every rotation when i replace the housing, always seems to be in the same place. I'm kinda thinking that the bearings are slightly out of line or have a slight bend to them?? I have tried ALIGN gears, clone gears, but still the same. The only way i have found to fix it, is to remove one of the bearings from the housing, so i am only using 1 on the gear shaft, instead of how it shows you in the manual and using 2. I'll be honest the clone gears seem a lot better than the align ones lol. I'm going to order some new bearings and gears just in case, but just wondered if anyone else had this issue?????
