450 450 odd behavior need help please
The first thing that I woudl check is that you didn't bump your elevator trim. If you did, reinitialize the gyro after putting the trim back in the center. If that is not it, then you will need to put a swash leveling tool on the helicopter and level the swash in DIR mode (given you are running a 3GX). This should take that drift out of it. Somehow, it's seeing a forward cyclic movement and pitching the nose down. Keep us posted.
Sparse
Hey tony went through the heli and found a bad servo, put a new one in and it seems to have corrected the problem. The one that was bad did not return to center after cyclic inputs. glad i stopped and looked everything over cause that could have ended really bad for me.
