Hello,
Been lurking here for a while.
Haven't posted much, but I learn more by listening than by talking.
Just got my HK450 Pro put together and have about 10 batteries run through it practicing hovering.
I've started to develop a problem and it seemed to be getting worse tonight.
Spun the main rotor up and just lifted off the ground when I seem to lose left and right cyclic temporarily and then it would come back.
Elevator and tail servos still worked just fine.
Also throttle seemed to work just fine.
I was able to set the heli down.
Everything appeared to work ok on the ground.
Another attempt, heli started to tip right and would not respond to left cyclic.
I had the blade tips disintegrate when they struck the ground. Use wood blades when learning, excellent advice
Only damage was the blades.
Replaced blades, spun it up again, I left the throttle at mid point and attempted to give a left and right cyclic, servos would not move.
The moment I shut the throttle down, everything worked fine again.
Tomorrow I will tear into it and check the RX and connections.
I am using 3 Corona DS-919MG servos for the swash plate.
Orange 7 channel DSM2 for the RX.
Turnigy 9x for the TX.
HK plush 40A ESC.
Turnigy Typhoon 2215 motor
ASSAN GA410 Gyro.
Power HD 3688HD Servo for the tail rotor.
I started spinning this up 3 days ago, Yesterday I was finally confident enough to hover.
All seemed to be going quite well until today.
This morning I could have swore that I lost left/right cyclic for a moment, but wrote it off to being nervous.
Tonight this problem really started to show up.
I have had a few landings that were a little hard, training gear came in handy.
Also fwiw, I have been practicing on a V911 fixed pitch for the last couple months.
Doing a little searching, I see a few people have had problems with bad solder joints in RX's.
I'll put mine on the bench tomorrow and see what I can see with the O'scope.
Anyway, just checking if anybody has had a similar problem or if someone has any advice on what to look for.
Thanks !
Don
HK plush 40A ESC.
ASSAN GA410 Gyro.
Thanks !
Don
