cn63bug
I am having a few issues when landing my 450 pro. On take off everything is smooth with a slight tendency to drift to the left but it's not that bad. While hovering and normal flight, everything is smooth and holds very well. When I attempt to land, as it's spooling down, it wants to tip over. It hasn't tipped all the way over yet, but it has come very close. It does seem like the head is shaking pretty bad at this point. I should also point out that it doesn't do it every time like this. Sometimes it's more severe than others.
What I am running is the 3GX with v3, align 325D Pro blades (not the 3G branded blades), stock servos, AR6210 receiver and the DX6i.
I've replaced pretty much everything on the head. Main shaft is true, feathering shaft is true. Blades are within .1 gram of each other and track true. Swash is level at low, mid and high. I have 12 degrees positive and negative in my main setup with about 8 degrees on my flight mode. Don't fly 3D yet at all. I am using the transmitter for dual rates.
My throttle curve is 0-42.5-65-80-100
My pitch curve is 35-42.5-50-75-100
Any help or suggestions would be greatly appreciated.
Thanks,
Chris
Thanks,
Chris
