Hi everyone. I have been trying to set up the rudder on my trex 450 3gx fbl, read the manual, seen some videos again and again, did the DIR setting, etc.. BUT when I try to do the rudder limit like rudder stick to the left, wait for 2 seconds, then the status led becomes red and blinking, but when I push the rudder stick to the right, it doesn't, the status led is just solid green. Tried it again, and sometimes I hit it, but after the setting the travel on the tail slider is just maybe 2mm and that's it. Tried to do it and same problem again, plus the tail pitch slider wont center after I do it.......... Can you guys help me on this pls.....
Thanks in advance..
pit
Thanks in advance..
pit
