Well I did not give up and go back to V3.1 like so many have on other forums, you would never guess how many 3gx haters that are out there,
Done a lot of reading on this last night and got no really helpful info out of any of it at all,
A couple of snippets maybe,
So here's what I done,
1. Turned down the rudder locking gain from 70 to 45
2. Turned up rudder gain on TX by 5%
3. Set up tail not in accordance with the manual, yes I did it different,
The manual says, set servo arm 90 degrees then adjust rod till slider is centred on tail shaft, this is how mine was with
V3.1 and it worked great, but was pants with V4
So my set up, is as above but adjust rod until 0 degrees of pitch on the blades, then redone limits.
Outcome, can now turn the tail left and right with no bounce back, happy chap again.
Hopefully if anyone else sees this issue you have somewhere to start as a fix.....
