When you have set up the parameters of the 3gx using the computer do you then have to "write" those parameters to the 3gx unit, do you have to press
the "write button" in the software so that they are remembered or does this occur automatically. Thanks in advance and a big, big thank you to
Tony for the series on the 3gx. Cheers. One more question, I down loaded 3gx v4 but is still says v3.1 on the software header is this correct.
