FBL Gyro 3gx help please
MartinJ
Hi All
I am a bit of a loss here. I have set up my DIR settings so that the Swash is perfectly level after buying a set of 6 horns. It is now perfect from zero throttle to full stick with no more than a 10 setup on the sub trim. However once I come out of DIR mode my elevator servo is sitting about 3mm below the other servos.
Any ideas
Thanks Martin
You don't happen to have any expo dialed into this Tx do you? If so, remove it and do the setup again. Remember, you must have 100% throws with no DR or expo.
If all of this is correct, the only other thing I can think about is creating a new model in your Tx and starting from step 1. Sometimes, the weirdest issues can be resolved from just starting over.
MartinJ
Okay. Thanks Tony.
There is no expo set up on this tx for this model. I did create another model with expo for use with Phoenix but having gone back to my 550 model all seems correct. I will try again from scratch. Thanks
