My servos are only moving less than 1mm up, will not travel down. Tried 3gx set up and nothing seems to work. I am sure it is something i have done, but i do not have a clue?
Can you re bind the 3GX and Rx and get into DIR mode and recofigure to get it to learn again? what if you bypass hte 3Gx and go direct into the Rx and see if you get travel?
Thanks Gaba, I got it. When i set up a new model on my TX i had to re-bind? I then did the 3gx setup and it worked. Then switched off the TX and heli started up!! Long story, then i had to do a re-build that kept me up till 2am this morning now the weather is too crap to test it
