I am trying to set the end limits on the rudder/tail for my Trex 450 v2 3GX running v.1.2. I press the setup button for 2 seconds to enter tail setup mode, go to the light for LIMIT and then set the left/right inputs from the transmitter making sure that the servo is not binding and leaving a little bit of space so the tail slider doesn't stick. I exit setup mode and enter flight mode and then test the range of rudder movement. Not only does the servo overextend from the limits I just set, but it also "sticks" on the ends and will not recenter without opposite direction stick movement. This could just be because I am on the ground without the blades spinning, but I just wanted to make sure this won't happen in the air. Any ideas? Thanks!
