1. Guest, Thank you for visiting Rc-Help. Please do NOT post tech questions in this section, post them in the Tech section instead. Thank you.
    Dismiss Notice
  2. If you would like to get rid of these banners and the ads within the posts, all you have to do is sign up and they will go away!
  3. Welcome to Rc-Help, are you here looking for the PDF Plans? They are located in the store in the tab above, but you must be signed in to access that part of the site. It only takes a second to sign up!
  4. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
3d Printer
Discussion in 'RC-Help Lounge' started by bigone5500, Aug 7, 2019.
< Happy Easter Birthday BigDave! | What Did You Do Today??? >
  1. bigone5500
    bigone5500 Well-Known Member
    Blog Posts:
    0
    Mar 22, 2017
    2,505
    66
    58
    Louisiana
    I thought you said you had the capricorn. I may not get that one and stick with capricorn. You haven't had any issues have you?
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,483
    1,410
    113
    I have had 0 issues with it, but replace the ends that it goes into as well. Especially if the ones you have has plastic fingers on the inside.
  3. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    2,505
    66
    58
    Louisiana
    Seems this is the package for me then!
  4. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,483
    1,410
    113
    Fancy cutter lol. I just used my pocket knife :D
  5. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    2,505
    66
    58
    Louisiana
    Razor blade to the rescue! I just like the fact that it comes with a cutter and all the pushlock connectors for just a couple dollars more.
  6. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,483
    1,410
    113
    No razor blade, just my pocket knife lol. But yea, that kit should work just fine. As long as the fingers are metal and not plastic lol.
  7. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    2,505
    66
    58
    Louisiana
    It said they're metal. We will see.
  8. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    2,505
    66
    58
    Louisiana
    @Tony Can you possibly take a photo of the extruder on your machine and post it here? I am wondering if it's the same one as on mine. You still use the stock one right?
  9. Tony
    Blog Posts:
    14
    Feb 21, 2011
    36,483
    1,410
    113
    I will have to get energy to take it apart to get to the extruder, but I'm sure it is the same.
  10. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    2,505
    66
    58
    Louisiana
    I'm 99.975% sure it is too. I have read and seen videos that say the Ender 5 is simply the Ender 3 Pro in a more sturdy frame.
  11. bigone5500
    Blog Posts:
    0
    Mar 22, 2017
    2,505
    66
    58
    Louisiana
    I tried to print the first of a set of chess pieces today and for some reason the print failed at about 65%. The nozzle made a terrible mess in the infill. I think I had my feed rate too high. Another thing I had a problem with is the feeder kept slipping which is probably due to too high feed rate. The nozzle temp was probably not high enough to keep up. I'll adjust it tomorrow and see what happens. My plan is to decrease the feed rate, slow down the print speed to 35, and increase the temp to 205.
    Failed print.
Share This Page
