I think I have become an expert in the 130x tail issues with all I went through to resolving my tail problems.
Now I have a head wobble that is pretty bad. It is usually only while decending so off loading the head.
I have tried new blades, new aileron servo(mine magically just stopped working),adjusted the gain on the main board to -3 on both aileron and elevator, I also checked that both blades are at 0 degrees at midstick, I also have the red O-rings installed.
Feather shaft isnt bent, blade grips are fairly new. Maybe a CG issue since I have the HP08 motor now?
This helicopter is realy starting to frustrate me it seems everything just decided to fail all at once at the exact same time ugg.....
