.1 probably isn't going to be noticable except perhaps in blade tracking. You'll have to look at that when you get it in a hover and see if you need to adjust one of the blades or not.
I agree with Matt, see if you can get that min/max of the second blade closer to the first. Seems odd that one is so well balanced between the two and the other is skewed.
How are you measuring pitch? Manual dial guage or a digital pitch guage? IN either case make sure you measure from the same location in the sweep of the rotor (usually with the blade pointing straight out from the nose of the heli). Do not move your gauge around to different locations around the heli, move the blades to your measuring position.
