500 WalkeraD03, 450, wanting to put a Three Main Blade system on
Dennis H
As title states, just playing around, where do I acquire part to convert my 450 to a 3 Blade system, main and rear Rotor Blades.
The main question, what issues "may" I run into doing this.
Dennis
PS: I have a TRex 600 that I would also consider doing it to as well.
The Trex 600 (pro) has an official 3 blade conversion for head and the tail. I don't know if Walkera ever did a 3 blade version? You can get three blade heads for the trex 450, if the shaft size was the same you may be able to use one on the Walkera?
You don't really gain anything in terms of performance, and you usually lose a bit of flight time, but three blade heads do look 'cool'.. which is the main aim for most people doing the conversion.
Dennis H
Yes, you're correct, just playing around.
Dennis
Only thing I have head about the 3 blade is cyclic response is way better. Other than that I have not head anything else. Well maybe the whole it flies like the sim deal.
