General VL912 not behaving
BT1969
Hi everyone, new to the forum and looking for some advice.
Been flying my VL912 copter successfully for a couple of days, bought 1000mAh battery to extend the flying time between charges.
Everything going well , less crashes and more controlled landings!
Then changed batteries yesterday as usual and the copter barely lifts off the ground, goes backwards and tilts to the side and crashes...!
Everything looks intact, both batteries fully charged.
Have switched off and on again several times and repaired with the transmitter- same every time.
Help !
If I remember correctly, that is a brushed motor. I will bet your brushes are worn out and the motor needs replaced. But, if this is a new(ish) bird, I would be talking to who you purchased it from.
