Hopefully this is where I can ask a question, get some advice. if not let me know...I'm old... I have a trex 600 and everything works just fine, surprise, surprise... only problem is, the elevator is working backwards, not good, I just can't think that fast. I 'reversed' the servo and that screws up everything else, throttle, pitch everything. I've tried reversing each servo...throttle, aileron, elevator, rudder (* I knew that wasn't it but tried it anyway...)gear, pitch, aux 2 and 3...nothing works for the betterment. it hovers fine, idles up fine, pitch collective works as it is supposed to... just forward is backwards, and backwards is forwards...one thing I noticed is that even when just moving the elevator, the other two servos work 'a little bit' as well.. but when I try to 'reverse ' the elevator, that affects the settings on the other two.. and throttle...I just don't know what else to try.. any help will be Greatly Appreciated. thanks again, Blessings, As Always, I Remain...
