500 Trex 450L Servo Update Rates
Harford
I have Trex 450L Dominator Super Combo with Microbeast Plus.
This kit has DS450 servos x 3 for the swash and a DS455 servo for the rudder.
MicroBeast set up menu points B, C and D require the following :
Swashplate Servo Update Rate
Rudder Servo Center Pulse
Rudder Servo Update rate
I cannot find this information for DS450 & DS455 servos as the website wiki.Beastx.com does not list DS450 and DS455 servos. I have asked Align with no response.
I can guess the answer is :
Swashplate Servo Update Rate - 200Hz (use blue)
Rudder Servo Update rate - 333Hz (use flashing blue)
I am making this assumption purely because most Align servos appear to have these rates. I am more confident that the Rudder Servo Center Pulse is 1520us (use blue) as this is a spec listed in the 450L manual.
Can anyone help please ?
Thanks
You are exactly correct on the settings. Cyclic will set at 200, tail will set at 333 and 1520.
