I picked up a Trex 450 Plus DFC (the BNF version) and bound it to my Futaba 14SG. All in all, it's a very tame heli which I believe is the whole point. I checked the Pitch angles and was surprised to find that I had virtually no negative pitch and positive was a mere 8.8. I checked the swash and found that I couldn't dial in any more than negative 2° and positive 11°. That indicated the my swash was too high so I adjusted the links 2 turns down. It improved a bit, but still was unable to get adequate throw to even up the pitch. No matter what I do, it seems that I only have a full range of roughly 13°. Setting 0° at mid stick would only give me -6°/+6° which is too low a number to really fly. I'm wondering if there is interference with the 3GXMRS unit that is preventing proper pitch adjustment. Is there a way to disable the MRS unit (such as holding the button on a regular 3GX unit when powering up)?
Anyone else have pitch settings for this heli? I think there may be some limits as it really IS aimed at beginning or intermediate pilots.
Thanks in advance.
Thanks in advance.
