ive just fitted a new zyx 3 axis gyro after (i think burning out) my zyxs because it just made my tail spin really bad and then the rx blew so it never got off the ground, anyway i have set-up the new zyx and the cyclic is working perfectly but no matter what ive tried so far the tail just spins once i get to half throttle, im sure its something in the gyro set-up but just incase i cant crack it, i want to check the symptoms
it has a torque drive fitted and the front gear turns on the shaft when i move it by hand, however when the motor is spinning everything is normal
what im thinking is that when the motor gets up to speed is it possible that the tail gear is then slipping and the tail is then not moving fast enough to compensate the speed of the front blades, because it only happens at half throttle before that it is fine, the other thing is that i have no to little tail authority the tail blades move and work fine but dont turn the heli either way
has anyone had this problem with the zyx or does it seem more a mechanical problem
thanks in advance
thanks in advance
