450 swashplate won't move when tilting left right forward backward
Murray
I have a devo 7E, tx RX2703H-D receiver I put this set up on a trex 450 pro flybarless heli the swashplate worked a couple of times, and stopped before i got done setting it up . I don't now what i did .I tried to rebind it and that not real clear how to do that. but move the pitch and it moves like it is suppose to move, the cyclic and it moves like it is suppose to. any ideas thanks in advance. Still working on it.
Hey murray. Try checking your solder connection on your battery or your ESC. I seem to have the same problem and it ended up beeing my connection on my battery. After a period of time plugging/unplugging the battery, it has he tendency to get loose on you. I found out the hard way....... in the air, not good! It's just a guest and good luck.
