General Spektrum Dx9 Black - Change Setup
Alex Evans
At some point, I tried to setup pitch curve / throttle curve using the 7 steps this Tx has.
Now, I want to go back to 5 steps which seems to be the nrom
But, the steps 6-7 are at ZERO, I need to make them back to be ----- instead
Any idea how?
Cheers
Alex Evans
I got it, thanks
It worked fine for Throttle curve, but Pitch curve in Normal mode, looks NOT as expected.
Looks like it hasn't reset itself to the 5 Point View, try re-booting the transmitter.
It should still work OK as only the vertical axis has any effect, have never seen that happen before, you have all the luck don't you.
Alex Evans
I tried that several times. What is even more intriguing - TU1 and TU2 are perfect diagonal lines, just Normal mode is NOT...
Cheers
delete all the intermediate points, leaving only the 0% and 100% points. Then add points back in at 25%, 50% and 75%
