Soldering Jig For RC Connectors
vimy
There are other types on the market, here is one that I like the look of.
As it says, being thermosetting plastic, (NOT thermoplastic) it doesn't absorb the heat so the joint doesn't cool down.
ProgressiveRC - ProgressiveRC Soldering Stand
Much better than burnt fingers and burnt benches.
If you Google it, and go to images, you will see the amount of connectors it is capable of holding.
Stambo
I have a piece of wood with holes drilled in it. :)
It was cheap and is easily replaceable.
I have a scrap piece of wood also. I drilled out some holes and bam, no more heat loss. I really like the smell the wood puts off when you get to close too.
vimy
