FBL Gyro Skookum sk540 tail problem
krash
the tail on my 600e pro does not return to the centre,only whn the usb is connected to lappy it returns,the firmware is 4.0 & the software is 4.1?
A little more info would help us to determine whats going on.
Have you flown the heli before, or is it a new build?
Is this the first heli you have set up?
When the tail gyro setting are in Head hold mode, the tail will not return to centre.
On the bench, when you give an input, the heli doesn't move. So nothing is telling the gyro to make a correction.
It will just stay where it is.
When you plug it into your lappy, its probably resetting the tail gyro, which returns it to centre.
