Hi D.O.G. Just to let you know latest, I am using a 3gx with satalites on the conputer, looked at video you sent and everything works like it should, Take it off
the computer, dissconect battery, turn transmitter off, When you turn transmitter on and put your safety switch on so cant start up, Then connect heli battery up let it do the checks lights flash head jumps up and down, When i put transmitter to one side, This is when my problem starts, When I go and pick heli up so i can test if SWASH is working correctly, forward/backward, side to side, BUT cant see swash moving in any direction, But if you put a finger from side to side of the heli you can feel slight movement on each servo arm. But dont know whot to do next to make it work, Iv missed something but dont know whot, Do you know where I may have gone wrong, ps there are no blades on heli for safety, Once again menny thanks for your help.
