General servo fault issue.
Murray Matson
Using DX61 and HXT900 servos on HK450. Servos are moving wildly randomly, causing crashes. Have replaced most parts ,except transmitter. Anyone had similar issue ???
Is it a Flybarred heli or FBL?
Do you have another RX to test the servos on?
Check the monitor screen in your DX6I, to make sure the stick inputs are smooth.
A good cheap investment, is a little servo tester, to check the servos separately from any other influence.
Thank Lee. Its flybarred. Have used separate RX, same result.Changed servos. The only thing I haven't changed is the transmitter, but its not that old, which leaves me confused. Has anyone had issues with DX6is ?
Did you look at the Monitor screen?
Check if theres any twitching on the monitor from the individual channels.
Then your last resort, is to try and find someone with another radio and see if that helps.
Do you have a Hobby shop nearby? I'm sure they'd hook it up to a shop radio and test it for you.
