General Servo Arm Ball Placement
Hello everyone! I was wondering if it would be okay to place my servo balls on the outer hole of the servo arms. I noticed that with them on the inner hole the links are not perpendicular to the swash/servoarms. I am a novice with my heli pitch/pitch curves set very docile.
I am also having servo interaction issues with the aileron slightly traveling more than the other two servos...but not my much at all
Not to mention using the outside ones would make it more responsive. If you're on a docile setup on the Tx then there isn't a good reason to switch up to the outside holes yet.
What heli is this for?
The instructions should give you a set distance from servo centre to put your ball links.
I would go with what they recommend.
As for the uneven travel. It will depend on whether you are running FBL or FB
On FB you can adjust the travel in the radio for that servo to bring it into line with the others.
If its FBL, it will depend on the unit as to which way you can do that. Some can been adjusted the same way,
others may need it to been done within the FBL unit software itself.
