450 Re Align 450 Pro V2 3GX build
Oldie
Hello just assembled helicopter and trying to set up.
Have futaba 6EX-2.4Ghz radio and 7 Channel receiver.
Cannot get Aileron control to work on 1 and 6 channel.
The left servo works okay and works on collective..Any help would be apprecated.
I don't know anything about Futaba Tx's but you may have to change your swash type to 120º CCPM. And make sure you are on the Heli setting and not Plane.
Hook up Rx first, bypassing the 3GX, this way you can troubleshoot the Rx until you have got it working.
I see it is a common problem setting up Rx with 3GX, as there are many small differences in radios as well as Rx's.
Actually there is a port on the 3GX for the futaba Tx's. You still have to use the Rx, but it's only a one wire hookup if I read it correctly.
Thank you Tony.
Not sure what you mean by a port on the 3GX.
Thank you Stokke.
I did hook up RX and everything worked fine.
As soon as I hook up 3GX it all changes. Aileron control only works on right side.
It slows down movements and the pitch control slowly drop down.
Note.. I have to use the extra wire to power the RX from 3GX batt port.
Any help would be appreciated. Keith
If you are getting lights on the 3GX, then you are very close!
Please see my post on the wiring of 3GX combined with external Rx here.
If this does not help you, I suspect there is some other problem at hand.
