I have all but 6 test hovers logged on this app. I have all my flights from the Pulse Ultra packs. So far I am liking the app and how easy it is to track your stuff.
So let's get into it. The first thing you need is the app. I know it runs on android but not sure about iPhone. Next you will want to print out the qr code images for your batteries.
Next you will need to enter in your batteries and then attach the right scanner code to the pack. Once the packs are entered the bar code will link to it corresponding battery.
As you can see it's rather simple so far. Next you will want to enter in your model information.
Now it's time to charge and fly. After the pack is done charging just scan the bar code and enter in the information from the charger.
The drop down that says charge has many different options. Use the entry that best applies to your situation.
The first slider I think is the mah of the pack, the second slider is for how many mah was put back into the battery. I will look into this later tonight, because I may need to make some changes if I am wrong.
----UPDATE- ---
OKAY the slider for the mah is for how many mah is left in the pack. After storage charging after my last flights I noticed that if you enter your storage mah your battery icon will show a half charged battery.
After a few flight updates and charge updates you will start to see the benefits from flight Times to quantity of flights on a kit or pack. Also after a flight I scan my pack and update the pack info. Once you do that you will see which packs are charged and which are not.
I have updated my Gqui X3 with the repairs from the first crash. You will see a total cost entry under the model.
Lastly there is an event screen. Here you will see all the flights and repairs of a particular kit or pack.
If I missed something let me know and I will add it. Anyhow hope this helps someone. At this time I am not sure how I can get the graphs to work. Most of them say not enough data logged.
----UPDATE- ---
