Trex 450 Pro V2 stock with Torque tube tail drive. Does have a Tarrot boom.
Had a crash and bent the tail boom. At least the 10th time I've crashed this heli.
Repaired her before and back up in the air without a problem.
I spool up the heli on the bench without the main rotor head and I get a strong vibration in the tail that resonates through the boom struts and vertical when at mid stick to the point that it will numb the finger tips to the touch.
I have chased this vibration to the point that I have literally changed every bearing (I have yet to rebuild the head but it is not on the heli) the in the heli from the main shaft (completely rebuilt the main shaft assembly), to the tail boom mount (bearings and gears) down to the bearings in the tail grips. I have tweaked the gear mesh while checking the gear mesh throughout it's rotation.
There is no evidence of the vibration running the following tests, motor only; motor and main gear only; motor, main gear and torque tube drive assembly only; motor, main gear and torque tube drive assembly and torque tube only. motor, main gear and torque tube drive assembly and torque tube and tail umbrella gear and tail drive shaft (without tail assembly). Once I install the tail assembly I get the vibration. I have completely rebuilt the tail rotor assembly and made sure it slides like silk. I am using a second new TT with new bearing and dust cover (off center).
I have tried it in HH mode and rate mode with no difference.
Could it be the motor getting weird? I only have maybe 20 hours of light flight time on the heli. No 3D
Can some one help before this heli takes a manual thrust flight out my second story window...lol
