Phoneix V3 and DX6i settings.
Bruno
Will I be able to south from normal mode to stunt mode while using the software or do I have to reprogram the TX with the software each time?
Thanks.
CORRECTION: Will I be able to switch from normal mode to stunt mode while using the software or do I have to reprogram the TX with the software each time?
Bruno
In other words, can I choose which ever model setting I have programmed in my TX , fire up the software and will it recognize those model-specific settings?
You will need to set the Tx up once you hook it up to the software. You will select what switch does what, set your curves and DR/Expo and get the heli flying like you want it to. Once you are done with that, it will stay in the program and in your Tx for later use.
stokke
Like Tony said, the radio set-up is done only once. After that it's just launch Phoenix and fly :D
Stunt mode/Idle Up can be used as it would in the real world.
