Thanks, The double post didn't show up at my end unless you moved it before I saw it.
Today I have made more progress on the arduino side of the project. I discovered that when running the micro controller on
USB power, voltage readings wont be stable. When running on a 2S lipo the readings are more stable. I am still not seeing the correct voltages per cell. I have used a 9v battery to get the numbers to calibrate the voltage dividers. I also took a reading from the 5v socket at the voltage regulator. I have used these numbers to help calculate the final voltages.
I finished the preliminary UI which is nothing fancy just some basic layout stuf and 2 buttons to turn on/off the discharge circuit. The buttons are programmed and functioning. I tested it on a led circuit.
