Stambo
After crashing my wing a while back, long story short, wrong model selected on tx, I have been looking for a smallish high performance pusher to put the electronics on.
I was never happy with the tail waggle that seems inherent on most wings so I won't build another.
This will be for proximity FPV so has to have room for stuff inside.
I haven't been able to find plans that I am happy with so I decided to make my own.
I have started with a cardboard mock up to get things looking right and figure out what I need to do to get the CG right.
Wing span is 750mm, power from a 2700kv 2205 DYS quad motor with a 6045 prop.
Might even stick a Naze in there for some stabilization.
I have a choice between 3s 850, or maybe 2 parallel, or a 3s 1800, as that is what I already have.
Depends how the CG works out.
Gonna make the control surfaces a bit bigger and use a KFM airfoil for the wing but beyond that it should be pretty much as you see it.
Any other suggestions are welcome.
