Hello
It's still Cold and Snow outside here in MI.
I've had plenty of time to check and recheck my setup as well as the mechanical operation
of the swashplate.
Also established communication via the lap top to the beastx.
The Updater program worked and is done.
The MicroSetting program may still need some adjustments?
Set the user defined geometry to 1 servo and the phase angle to 120.
The swashplate servo frequency was 200 and reading but C and D were not reading.
Set C at 1520Hz - Tail Servo Center Position Pulse Lenght.
Set D at 333Hz - Tail Servo Frequency.
And they starting reading.
Have not messed with the swashplate mixer, still at zero. Or not set.
Please advise if you think I'm doing something wrong, Hate to burn up another servo.
But if I do, I hope it's on the bench, not in the air, at least I have that going for me.
I attached my setup files for the DX8 and AR7200BX to review.
These are just a basic, get off the ground values i am using.
TREX450 v1
FUNCTION LIST:
SERVO SETUP: Index: 0 1 2 3 4 5 6 7
THR AIL ELE RUD GYR PIT AX2 AX3
TRAVEL: 100 / 100 100 / 100 100 / 100 100 / 100 100 / 100 100 / 100 100 / 100 100 / 100
SUB TRIM: 0 0 0 0 0 0 0 0
REVERSE Normal Normal Normal Normal Normal Normal Normal Normal
SPEED: Norm Norm Norm Norm Norm Norm Norm Norm
D/R AND EXPO High,Left/Low,Right
Sw: AIL ELE RUD
DUAL RATE: POS 0: 100/100 100/100 100/100
POS 1: 100/100 100/100 100/100
POS 2: 100 / 100 100 / 100 100 / 100
EXPO: POS 0: 40/40 40/40 30/30
POS 1: 0/0 0/0 0/0
POS 2: 0/0 0/0 0/0
THROTTLE CUT: POS: 0%
Sw: Hold
LOW 25% 50% 75% HIGH EXPO:
THROTTLE CURVE: NORMAL: 0% 25% 50% 75% 100% Act
POS 1: 90% 85% 80% 85% 90% Act
POS 2: 95% 92% 90% 92% 95% Act
HOLD: 0% 0% 0% 0% 0% Inh
GYRO: Pos 0 Pos 1 Pos 2 4
37.0 37.0 -30.0 Pos 0 Pos 1 Pos 2
Plus Trim: 0.0 0.0 0.0 Ch Index 4
Total: 37.0 37.0 -30.0
43 GYRO
CH: GEAR SW: GYRO 5 GEAR
PITCH CURVE: NORMAL: 0% 25% 50% 75% 100% Inh
1: 0% 25% 50% 75% 100% Inh
2: 0% 25% 50% 75% 100% Inh
HOLD: 0% 25% 50% 75% 100% Inh
TAIL CURVE: NORMAL: 0% 0% 0% 0% 0% Inh
STUNT 1: 0% 0% 0% 0% 0% Inh
STUNT 2: 0% 0% 0% 0% 0% Inh
MIXING: CYCLIC>THRO SWASH
AIL>THRO: L 0% AIL>ELE:L 0%
R 0% R 0%
ELE>THRO:L 0% ELE>AIL:V 0%
R 0% D 0% AR7200BX: Preparing the Transmitter for Flybarless Operation #3
RUD>THRO:L 0%
R 0% Never enable your transmitter's eCCPM or revo-mixing
N 1 2 H M N 1 2 H M functions. This is handled by the AR7200BX
MIX 1 THRU MIX 5: INH>INH
RATE: 0
0
OFFSET: 0
TRIM: INH
N 1 2 H M
RANGE TEST:
TIMER: MODE: COUNT DOWN
TIME: 7:00 TONE
START: THROTTLE
POS: 25%
INTERNAL: RESET (RUNNING TIME)
SYSTEM SETUP:
MODEL SELECT:
MODEL TYPE: Heli
MODEL NAME: TREX450 v1
SWASH TYPE: 1 SERVO NORMAL
SW SELECT: TRAINER: INH MIX: INH
F MODE: INH HOLD: INH
GYRO: INH GOV: INH
L TRIM: INH R TRIM: INH
KNOB: INH
F-MODE SETUP: FLIGHT MODE: F MODE AILE D/R ELEV D/R RUD D/R GYRO F MODE GOV MIX
HOLD: HOLD HOLD HOLD HOLD HOLD HOLD HOLD HOLD
TRIM SETUP: THR: 0 R TRIM: 0
AIL: 0 L TRIM: 0
ELE: 0
RUD 0 TYPE: COMMON
WARNINGS: THROTTLE: Over 10%
STUNT 1 Act TIMER:
STUNT 2 Act START: 10%
HOLD Act TIME: 5 Mins 0 Secs
ALARM Tone AUDIO: Enabled
VIBRATE: Disabled
TELEMETRY: FLIGHT LOG: ALARM: TACHOMETER:
Frames: 0 Disabled RPM Min: 0 0 1 1 TACHOMETER: Display: Enabled
Holds: 0 Disabled Max: 10000 0 1 RPM Min: 0 0
Rx Min V: 4.3 Disabled Ratio: 100 0 1 Max: 10,000 0
Rx Max V: 8.1 Disabled Poles: 0 0 1 Ratio: 100
0 0 0 1 Poles: 0
0 0 0 1
1
FLT PACK VOLTS: TEMPERATURE: 2 1 FLT PACK VOLTS: Display: Enabled
Min: 9.5 0.02 TEMP MIN: 0F INH 2 Min: 9.5 0.02
Max: 12.8 0 TEMP MAX: 150F INH 2 Max: 12.8 0
0 0 0 0 0 0 2
0 0 0 0 0 0 2
0 0 0 0 0 0 2
0 0 0 0 0 0 2
3 1 TEMPERATURE: Display: Enabled
3 TEMP MIN: 0F INH
3 TEMP MAX: 150F INH
3
RELEVENT 3
3
3
UNSURE NOT SET UP YET 3 0 POWERBOX: DISPLAY: Disabled
3 V1: INH CAP 1: INH
3 V2: INH CAP 2: INH
NOT REVELENT 3 RPM: INH TEMP: INH
3
3
FRAME RATE: 11 ms 3
MODE: DSMX 3
TRAINER: INH 3
PROGRAMABLE MASTER 3
PILOT LINK MASTER 3
SLAVE 3
SYSTEM SETTINGS: USER NAME: SETTINGS: DISPLAY: ROLLER 4 1 AIRSPEED: DISPLAY: Enabled
CONTRAST: 10 UNITS: US 4 SPEED MIN: 0MPH INH
MODE 2 4 MAX: 621MPH INH
REGION US-247 4
LANGUAGE: ENGLISH 4
BATTERY ALARM: 6.4V 4
BATTERY TYPE: LiPo 4
INACTIVE ALARM: 60 min 5 1 ALTITUDE: DISPLAY: Enabled
BACKLIGHT: Auto ATL. MIN: OFT INH
LED: 100% MAX: 800ft INH
SERIAL NUMBER: XXX
XXX
XXX
v2.06
TRANSFER SD CARD: OPTIONS: SELECT OPTION
STATUS:
FOLDER:
Hello
of the swashplate.
TREX450 v1
FUNCTION LIST:
Sw: AIL ELE RUD
POS 1: 0/0 0/0 0/0
POS 2: 0/0 0/0 0/0
Sw: Hold
43 GYRO
R 0% R 0%
RUD>THRO:L 0%
RATE: 0
0
OFFSET: 0
TRIM: INH
N 1 2 H M
RANGE TEST:
TIME: 7:00 TONE
START: THROTTLE
POS: 25%
SYSTEM SETUP:
MODEL SELECT:
MODEL TYPE: Heli
GYRO: INH GOV: INH
KNOB: INH
AIL: 0 L TRIM: 0
ELE: 0
RUD 0 TYPE: COMMON
STUNT 1 Act TIMER:
VIBRATE: Disabled
0 0 0 1 Poles: 0
0 0 0 1
1
0 0 0 0 0 0 2
0 0 0 0 0 0 2
0 0 0 0 0 0 2
0 0 0 0 0 0 2
3 TEMP MIN: 0F INH
3
RELEVENT 3
3
3
3
3
FRAME RATE: 11 ms 3
MODE: DSMX 3
TRAINER: INH 3
PILOT LINK MASTER 3
SLAVE 3
REGION US-247 4
LANGUAGE: ENGLISH 4
SERIAL NUMBER: XXX
XXX
XXX
v2.06
STATUS:
FOLDER:
