MurryB
Well screwed up lost all settings for trex 450, trying to calibrate the radio sticks.The cal on the sticks didn't seem to work. The throttle is not right and when you move the aileron stick you push right pip moves left push left pip moves right. The same with rudder. The throttle is off, if you set it on the center tic mark and look at monitor it is almost a full tic mark off.
